Speakers for Pioneer PDPLX508D
Discussion in 'Plasma TVs Forum' started by creative, Aug 6, 2013.
  1. creative
    creative
    Sep 14, 2002
    174
    +5
    I really dont want to buy a set of L/R speakers specifically for the Plasma if i can avoid it, particularly as the space is tight.
    Need a way for wiring my existing kef 5005 speakers (fronts) to both the Pioneer LX508D as well as using them occasionally with the av setup (via denon AV receiver) - without swapping the speakers cables around ;)
    If connecting my exisiting Kef isnt an easy and cheap option, then may consider getting a speaker bar which i can place under the plasma and top of a cabinet.
    Any suggestions on the kef / speaker bar options (Pioneer or non Pioneer)?
  2. JayCee
    JayCee
    Jan 20, 2004
    23,764
    Lanarkshire
    +2,572
    You cannot run speakers directly from the Tv (unless they are PC-type speakers with a built-in amp).
    You need to connect the audio out from the Tv to your AV amp.
  3. creative
    creative
    Sep 14, 2002
    174
    +5
    The Pioneer plasma has a left / right speakers terminals. This is for adding a undermount or left / right speakers.
  4. vidjo
    vidjo
    Dec 4, 2009
    261
    28
    +41
    And about 15 watts per chan amp built in. I run a good pair of speakers from mine and it sounds good.
  5. creative
    creative
    Sep 14, 2002
    174
    +5
    So the original question(s) was:
    Any suggestions?
  6. JayCee
    JayCee
    Jan 20, 2004
    23,764
    Lanarkshire
    +2,572
    Thanks, that's me learned something about this model then.
    I still think your easiest option is to run the audio out to your AV receiver...why not...are they not located next to each other?
  7. creative
    creative
    Sep 14, 2002
    174
    +5
    Just trying to make life easy for the mrs...switching on the TV and then the AV gets a bit much....
  8. JayCee
    JayCee
    Jan 20, 2004
    23,764
    Lanarkshire
    +2,572
    That's where a Harmony remote scores...1 press of a button does it all.
