Speakers for PC use !!!
Discussion in 'Home Cinema Speakers' started by DodgeTheViper, Dec 23, 2001.
  1. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,688
    Inbetween Upgrades !
    +8,135
    I have just upgraded my speaker system from the Mirage AVS-500 sub/sat system to M&K K Series , with the intention of selling the Mirage system .
    In the meantime i have had on my shopping list a speaker system for my PC , which has a Soundblaster 5.1 soundcard . I have been looking at something like Creative's DTH 3500 system or Yamaha's TSS 1 , reviewed in this months HCC . Then i thought what about the Mirage system ???
    If i chose the Mirage system would this be better than those mentioned for my PC , or would it be overkill ? Also how the hell would i connect it up ?
    Any help appreciated
    Kev
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    If the Mirage pakcage is 5.1 as I suspect (what with this being a HC forum) then I would buy a cheapish receiver/amp to go with them,such as the Denon 1602/1802. It must have a 5.1 input for use with a 5.1 soundcard until PC games and soundcards support DD and dts properly. You should connect it using both a digital lead of some form, optical or coax depending on what your cards has as an output, and using a 4 or 5.1 analogue output into the 5.1 input.
    Good luck, and have fun!
  3. dochall
    dochall
    if you do go for a pc system rather than the mirages be aware that the creative speakers are all being replaced. The top of the line system (Megaworks 510D ?) have had some good early reviews and look interesting.
    Alternatively look at the Videologic range and Kilpsch.
