speakers for music dvds
Discussion in 'Home Cinema Speakers' started by gooner265, May 16, 2002.
  1. gooner265
    gooner265
    Hi all , I purchased a pioneer home cinema system package which i'm very happy with watching films but i have a lot of music dvds now and the small speakers give no depth to the music.
    My question is will it hurt my amp if i wire my hi-fi speakers up to the front left and right sockets instead of the two smaller ones. they are from a sony midi system.My amp is 280 watts and has seperate 110 watt sub.
    If I did this is there anyway I could have them wired to my hi-fi and my amp so I can use them for either my hi-fi or amp without having to keep changing the wires over.
    any help much appreciated.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Does the AV amp have pre-outs for the front speakers? Then you can connect those to any free line input (e.g. AUX) on the stereo amp. The front speakers connect to that and thus no need to switch cables, just the input at the (stereo) amp.
  3. gooner265
    gooner265
    no the only speaker connections are the six for 5.1
  4. Bonesy
    Bonesy
    Feb 22, 2002
    1,161
    Wiltshire
    +29
    Hi Reiner, (biggest hijack ever about to happen :eek: )
    So have you left Nokia?
  5. Bonesy
    Bonesy
    Feb 22, 2002
    1,161
    Wiltshire
    +29
    Gooner, sorry felt guilty
    I would not risk what you are proposing, as the chance of getting signals from both wires is there, and I'm not sure what it would do to a speaker.
    My system uses the approach described by Reiner, pre-outs to the aux of the hifi amp.
    Is it easy to list what outputs you have from the home cinema box to see what other options might appear?
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Just to clarify: I mean line level connections, not (amplified) speaker connections.
    @Bonesy: yes, I was retrenched last year November. Now I work for a small company in Taiwan, same line of business actually.
  7. Bonesy
    Bonesy
    Feb 22, 2002
    1,161
    Wiltshire
    +29
    Gooner, yeah, what model number is the pioneer?
    Reiner, just two weeks left of my notice period here, hence the amount of posts;)
