Speakers for Marantz SR-5400...?
Discussion in 'Home Cinema Speakers' started by Sly Fly, Nov 23, 2004.
  1. Sly Fly
    Sly Fly
    Nov 23, 2004
    Having decided to take the plunge into Home Cinema, I am... astounded at the choice there is for AV's and Speakers.
    After a lot of trawling through, I have sort of settled on the Marantz SR-5400 (£269 best so far), thanks in no small part to the reviews I read about them here. One small niggle is that I know it is good for music, but I will be using it 80% for films. The reviews have said it is also more than capable though.
    Right. Speakers - I don't want to spend that much on them if poss. Definitely not more than £400, and ideally somewhere in the region of £300. The Mission FS1's look awesome, but expensive. Can you lot suggest something good around this mark that will compliment the 5400?
    Cheers, and great site!
