Speakers for Denon DM31 Micro System
Discussion in 'Home Cinema Speakers' started by steve 111, Nov 16, 2004.
  1. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Thinking of buying the Denon DM31 Micro Hi-Fi System for the bedroom. Most retailers are taking £50 off if you buy the unit without the Denon speakers. Am I better off buying the system with the supplied speakers or can I get something significantly better in the £50-£60 range by buying seperately?
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    I think the speakers that come with the denon are little Missio m30's although i'm not sure, for cheap speakers your best bet is richer sounds but all the reviews i've read have said the speakers that come with are really good.
    So I doubt you'll get better for £50-60, although you might if you can get some ex-demo/second hand. If they are significantly better though is another matter altogether.
