Speakers for denon dm31 help please
Discussion in 'Hi-Fi Stereo Systems & Separates' started by pete1866, Nov 6, 2004.
  1. pete1866
    pete1866
    Oct 25, 2004
    705
    28
    +34
    Hi i am going to buy a denon dm31 , what speakers around the 100 to 140 pound mark should i buy , i have seen some tannoy mx2 m for 100 pounds new or some second hand mission 751 , any advice would be most appreciated thanks
  2. Crocodile
    Crocodile
    Nov 4, 2002
    15,300
    +4,572
    Where are you intending to buy the Denon from? If you have a branch of Richer Sounds near you then you should be able to try some speakers out with the Denon at the time of purchase. A good starting point, & ridiculously cheap, is the Mission M71i at only £60. I have a pair of these on a DM30 & I'm very pleased with them, but only you can judge what sounds good.
    Also bear in mind that something that sounds good in the shop may not sound so great once you get it home. RS are usually pretty good when it comes to exchanging items that don't suit.
  3. CJROSS
    CJROSS
    Nov 16, 2000
    5,070
    +343
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,501
    Edinburgh
    +1,237
    Monitor Audio Bronze B2s work very well with the DM31 and come in at £140.
  5. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    Sorry, £140 for the B2's - isn't it the B1's that come in at £140?
    Have been thinking about replacing a pair of ten year old Mission 733's that I use with my DM31 - could be very tempted if the B2's are £140!
  6. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,501
    Edinburgh
    +1,237
    Yes, sorry meant the B1s not the B2s. Still, they are very good for a little system like the DM31.
  7. pete1866
    pete1866
    Oct 25, 2004
    705
    28
    +34
    Thanks for your help lads plenty of food for thought , will give all your advice a good study cheers
  8. RickT
    RickT
    Anyone heard the new Mission M31i speakers? I wondered if they would work well with the Denon DM31. I need a system and have decided on the Denon DM31 but am undecided about speakers - max £140
    RickT
