Speakers for Denon AVR-1910
Funkoid
I'm after two options for this amp, the first a sub/sat package and the second being a custom seperates option! :thumbsup:
Passingbat
You need to post a budget to get relevant suggestions.
Funkoid
Oops! Sorry thought I had... With the amp going for between 350-400 i'd be looking at between 350-500'ish!
PSM1
For sub/sat I would look at the Jamo A102.
For others I would look at the Q accoustics 2000 AV speaker package.
Passingbat
For that price, you're going to strugle to get separates unless you build up over time and just get the front three speakers as a start.
the advantage of 5.1 sets is that you seem to get savings for buying at the same time.
At the top of you budget, these are a popular choice and good match for the Denon.
Q ACOUSTICS 2000 5.1 HOME CINEMA SPEAKER PACKAGE - available from Superfi UK Visit http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/product_id/5697 for details
You may be able to get the range that they replace for £350, but they are getting scarce.
Q Acoustics 1010i 5.1 Black | 5.1 Speaker Package | Richer Sounds
If you can get the £350 ones, they would be the better buy as the new ones won't be £150 better.
Passingbat
