Speakers for denon avr-1803
Discussion in 'Home Cinema Speakers' started by Kirth, Jun 1, 2004.
  1. Kirth
    Kirth
    Jun 1, 2004
    10
    Hey,
    Been browsing for a while now, and decided it's time I ask and see what people think.
    Right now, I have a denon avr-1803, with a M&K center that I borrowed from a guy at work. The fronts + rears arnt even worth mentioning as they are bits I re-used from random things!
    Now, what to replace them all with ?
    I just looked at something like this:
    2x Mordaunt short 902A (front + rear) - 149.90 each
    MS905A center - 119.90
    MS907A or MS309A sub - 219.90 / 215.90
    this comes to somewhere near 669pounds roughly. Now, I'd be buying this bit by bit (I think anyway), most likely starting with sub + rear's. I dont have a sub atm, and the rear's I'm using are rated 15w... and really poor!
    So, I'm asking :
    1. What does that set up look like to you ?
    2. What possible alternatives (better?) are there for roughly same level of price.
    Then the next fun comes with cables/front stands ;)
  2. Kirth
    Kirth
    Jun 1, 2004
    10
    Also... had a look at teh KEF KHT-2005.2 Home Cinema System or the MS Avant plus system...
    Better off just buying one of them perhaps ? (Since it's obvious I dont know much about this all). The KEF gets good reviews, although I'm not sure about the looks ;)
  3. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,195
    2
    +3,667
    You might want to look at this months What HiFi which tests an Avant pack of 904's, 905 and 903's with a 309 for £780. It gets the proverbial thumbs up and would be very similar to the first pack you mention. The KEF KHT bits are are tour de force in home cinema terms but I would be confident that the MS pack would beat it for music and be well capable of handling an amp upgrade should that happen (and it generally does).
    The best advice I could give is of course- listen to both ;).
  4. paul710
    paul710
    Feb 16, 2004
    34
    Bolton
    Try listening to the Acoustic Energy Aegis 3B package - got mine 6 months ago and I have been well impressed by them - got them from Sound & Vision for £700.
