Speakers for Denon AVR 1705
Discussion in 'AV Receivers & Amplifiers' started by deepams, May 31, 2005.
Tags:
  1. deepams
    deepams
    I am looking to put together a home cinema system and have sort of decided on the Denon 1705 AVR. Price seems quite attractive and have a bias for the brand. what speakers will go well with this
    ...am looking for a 5.1 speaker system around £300. I plan to use this almost equally for music and movies.
  2. ferraris
    ferraris
    Jun 2, 2005
    26
    I'm looking at the AVR 1905 and am thinking of the Wharfedale 9.1 HCP set-up to go with it. About £250 I believe.
    Simon
  3. ps22571
    ps22571
    Jul 1, 2005
    10
    I'm going to boost this thread as I have the same question
  4. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    You can't run 9.1 on the 1705 or 1905 only 7.1 with the option of a second set of fronts for stereo.
  5. deepams
    deepams
    has anybody tried the wharfedale 9 set of speakers with the 1705 or 1905?
  6. White_Nemesis
    White_Nemesis
    Eddy Boy, 9.1 is a speaker series not a set-up :lesson: :D
    Deepams,
    Evertbody will hear differently, your room will interact differently.....
    Find a good retailer and demo some speakers within your budget (using your front end) narrow it down to 1 or 2 and then try them at home.
    Trust yoiur own ears!!! What YOU like is good :thumbsup:
  7. gseh
    gseh
    Jan 21, 2004
    37
    Glasgow
    I've partnered mine with Tannoy FX 5.1 speakers and am very pleased with the results. They're also well within your budget.
