Speakers for around £600
Discussion in 'Home Cinema Speakers' started by wallzy, Mar 7, 2005.
  1. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    i am currently upgrading my whole surround sound system i brought my amp its a pioneer VSX-1014 and i was wondering if some one could recomend me some speakers that would match this amp for around £600
    thanks for your help
    Wallzy
  2. Bobby Luvin
    Bobby Luvin
    If you want top quality floorstanders then i would recommend a pair of SCOTT with built in subwoofer driver cones and top, top sound quality. Look the Bizz and give out a very respectable 300 Watts RMS each. You won't even have to spend £600 These retail at £279.99 at argos and are well worth the money. Look into them buddy
  3. Bobby Luvin
    Bobby Luvin
    :smashin: If you want top quality floorstanders then i would recommend a pair of SCOTT with built in subwoofer driver cones and top, top sound quality. Look the Bizz and give out a very respectable 300 Watts RMS each. You won't even have to spend £600 These retail at £279.99 at argos and are well worth the money. Look into them buddy :smashin:
  4. Roohster
    Roohster
    Jul 1, 2004
    4,704
    7
    Derbyshire
    +5,790
    Wallzy, are you looking for just a pair or a full 5.1 setup?
    Floorstanders or stand mounters?
  5. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    just a pair of floor standers the rest of the speakers will have its own buget
    thanks wallzy
  6. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    bump ^^^^^
  7. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    The Quad 21L's would be lurrrvly :) You should be able to haggle the price closer to £600. They are quite neutral too, so won't colour the sound, you don't want an overly bright speaker with a Pioneer amp.
    Monitor Audio do some good speakers in that price range too, but might be a bit too bright. Don't dismiss Dali, I think Dali's would suit the Pioneer well as they should iron out any brightness and reign in the attacking nature of the 1014 (only if you feel it needs reigning in of course :) ). If you like the attacking sound, then the Quads would step out of the way and let you listen to it :).
    Wharfdale Evo 30's could also be an option (haggle down again :) ), and also the KEF Q7's.
  8. deanym
    deanym
    May 29, 2004
    1,833
    +143
    I agree the quads sound lovely - had a great demo of them a while ago, but the Wharfedale evo 30's are cracking. Designed by the same team as the quads, not quite as detalied but have a decent dynamic range and can pick out a tune wonderfully. I am a KEF fan, but found the q7's not so good for stereo - although more than up to a home cinema role.
    I listen to everything from the RHCP to Mozart and the evo's play them all very well. If you want the best out of a stereo set up, a separate stereo amp is worth it. If its for occasional listening then the current amp you have is perfect.
  9. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
  10. Matther54
    Matther54
    Obviously I wanna plug the monitor audio silver S series. I didn't find them overly bright, but its all about personal preference I suppose. With the new RS series due out quite soon you might be able to get a pair of S8s for around £600 if you haggle well! And they rock!!!
  11. Matther54
    Matther54
    however.. maybe I shouldn't say they wouldn't be bright with your pioneer amp, when I haven't heard them with it... :blush:
  12. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    The S8's and AE's are great speakers in their own right, but my personal opinion would be that they would be too bright with the pioneer, it may become tiresome after a while. Unless you like that kind of sound of course.
    Bet those S8's sound awesome with the Arcam though :D Great combo
  13. Matther54
    Matther54
    Yeah, you're probably right. I don't really know much compatibility between certain models. Haven't got enough experience yet ;)
    Afraid I only have the S6s which I picked up for £400 (Haggled rather hard!)
    But I do love them like part of the family :cool:
  14. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    thanks for your input im going to have a look at the speakers mentioned above and will let you know were i go from there
    would any one recomend the b&w DM603 S3
    thanks
    wallzy
  15. Matther54
    Matther54
    The 602S3 often gets referred to as better value for money.. It is alot cheaper. but it lacks that extra bass driver (although it sounds really great without it!)
    Try them both out. I wasn't hugely keen on the finish of the 600 series, but I was VERY impressed by the sound.
  16. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    The 603's are good, but not (in my opinion) in the same class as the Quad, MA or Whardales mentioned already, I would say give the Dali's a listen too if you can.
  17. Matther54
    Matther54
    Agreed. While I was really impressed by the B&Ws, I was more impressed by the MAs. Hence I bought them ;)
  18. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Castle Severn - good floorstanders
