Speakers for against a wall
ItsNotAllSnakeOil
Hi Guys
I currently have a Quad Vena 2 (Play) paired with some Oberon 5's which I am really happy with from a sound perspective, however the speakers being away from the wall is causing logistical issues with the TV, wife, kids etc. I can't really put them right up against the wall as it impacts the sound too much. Just a thought right now but does anybody have any suggestions for any speakers, bookshelf or floor standing that can be placed pretty much against the wall? Budget probably up to £1000. Happy to buy used but would prefer new.
Ugg10
Did the Oberon's come with foam port bungs. If so, try pushing them back and add the bungs to reduced the bass boom a bit. If not, then try some rolled up socks or a rolled up tea towel, you may be able to tune it, tighter roll will reduced bass more theoretically. Worth a try for free.
Also worth noting that Dail usually specify the speakers are point straight out into the room (no toe in) which should be OK for closer to the wall aesthetically.
if not you could try the Dali Menuet (SH) and a BK P12 subwoofer or front ported or sealed floor standers.
Spotted these Triangle Speakers, reading a bit suggestes they are designed to be close to the wall and at an rrp of £2.5k these seem to fit the bill but obviously an audition or sale or return is the best way to tell.
These Spendors are sealed units.
ItsNotAllSnakeOil
Thanks very much, will take a look. The Dali's didn't come with bungs actually but i will have a look at ordering some. I don't toe them in as you say, Dali's aren't designed to be. To be honest they don't sound bad right against the wall but they lose some energy and bass booms a bit, certainly don't sound as good as when they are away from the wall.
Ugg10
Before you buy anything, the rolled up socks/towel will give you a good idea if bungs are going to help, start with loose roll and then tighten up or add more socks/towels - port looks pretty big so towel may be better. Worth a try.
Baron Mole
Before you buy anything, the roled up socks/towel
Love it - been wondering what to do with my old socks - any bets on how long it takes for someone to ask whether the socks should be cotton or wool ? :rotfl:
Jester1066
I've heard if you use nylon socks it'll introduce severe static to your audio! 🤣🤣🤣....*
* Before anyone jumps in... I am of course joking! 🤣🤣🙊🤫
ItsNotAllSnakeOil
Tried some foam for the minute, actually does help quite a lot. Just not sure whether it's a good long term strategy. Don't suppose it can damage the speakers?
Jester1066
Unlikely to. Most manufacturers provide foam bungs for this very purpose. You can get different sized "universal" ones off "the Bay"
Helix Hifi
Hi Guys
Use the same speakers my self. I use toe in. It helps with imaging, bass response. Dali is respected company, but I just don’t see why so many say they don’t need toe in. The cabinet, drivers gives excellent stereo imaging with out toe in because of Dali’s driver technology, still I recommend members to toe them towards to listing posting. Probably people are concerned also because the sound gets bright if you do this, in my room I have no such problems.
ItsNotAllSnakeOil
Interesting, i haven't really toe'd them in at all as it says not too in the DALI manual. Might give it a try. I have never had issues with them being bright, certainly not with the Quad amp anyway.
Helix Hifi
I’d toe in as a said. There’s many benefits. Less reflection from the sidewalls. Also put some Ikea butcher blocks under the speakers or similar options. This helps with the bass response.
Helix Hifi
In my opinion whether a manufacturer says no toe in because all this depends on sitting position. But it is true that DALI has a big soundstage even if you don’t use toe in. Still in my room it works best if I do the opposite.
Paul7777x
Odd you should say that. A few days ago I bought some bamboo socks.
Surely these are the way forward...bamboo is the new port stuffer.
Helix Hifi
Apparently Sonus Faber can be placed against the wall because the bass port is placed under the speakers. Sealed speakers are probably the best alternatives. Those Spendor speakers sure look nice.
3rdignis
Secure the speakers to the floor.
Stitch under carpet. Allow 24hrs to stick to wood.
Ripped the plaster of my ceiling.
Excel wall bounce calculator.
Mark.Yudkin
Cotton of course. You don't want a woolly sound.:D
rccarguy2
I'd look at sealed box speakers, NHT or something like that
Baron Mole
Helix Hifi
Fyne speakers could work because of the down firing bass port placed under the speakers. Graham Audio has some sealed speakers also.
Helix Hifi
Try self adhesive sorbothane damping feet where the plinth is located. There are many too chose from-not expensive also.
Sonic Design, even washing damping feet’s work. Edit, it appears I mentioned damping feet’s in my earlier post. Any way perhaps it helps.
Or perhaps the Lyngdorf 1120 may resolve the bass response.
Baron Mole
:offtopic: THE RACE IS DECIDED Awards in the Ugg10lympics 2021
🏆 Goes to Ugg10 for inspiring the event with an excellent money saving suggestion.
Also Eco Award.
Event announced by
Medal Table
🥇 Gold
And the winner of the Gold Medal is @Mark.Yudkin :clap:🥇
🥈Silver
🥉Bronze with an Eco Award
Special thanks to @Steve356 for verifying the result.
Helix Hifi
Nice to have our own hifi Olympics. Now the national anthem blasts from the speakers.
Baron Mole
:offtopic:
Feel a bit naughty for hijacking the thread - so after this I'll stop. No honestly Gibbsy :nono: I will I promise.
Happy to take PMs on any ideas for future events. Or maybe have a seperate thread ?
Steve356
Also Eco Award.
Event announced by
Medal Table
🥇 Gold
🥈Silver
Verified! :thumbsup:
jobseeker
Just picking up on this thread to say that I’ve had success in the past by tuning bass ports with a collection of different sized drinking straws, cut to length and held together by tape. Could be worth a try.
Latest News
Triangle announces new wireless Borea Active bookshelf speakers
  • By Ian Collen
  • Published
Cleer Audio announces Arc earbuds
  • By Ian Collen
  • Published
iFi Audio launches new Go bar portable DAC/headphone amp
  • By Ian Collen
  • Published
Sony adds LinkBuds S to its earphone series
  • By Ian Collen
  • Published
T+A announces Solitaire T headphones
  • By Ian Collen
  • Published
