Speakers for a denon AVC-A10SE?
Discussion in 'Home Cinema Speakers' started by Frustin, Nov 1, 2001.
  1. Frustin
    Frustin
    I mostly watch films, and I dont want to spend to much more than £500 (but all things are concidered), i dont need a sub as i have a nice rel Q150E that i bought recently.
    I currently have tannoy MX2's and 1's as my front and rears. I have a NHT center (bought second hand).
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Hm, how does your current center integrate with the Tannoy? Perhaps a change to the matching MxC would be recommandable, especially if you consider replacing the fronts with the Mx3 or 4.
    That would probably the cheapest upgrade, I would not know of any set for GBP500 which would really be an upgrade as I think the Tannoys perform very well, so to hear a noticable difference you would probably need to spend a bit more.
    Then again let's see what others have to suggest ...
  3. Frustin
    Frustin
    but is the MXC really an upgrade over the NHT that i have, i know about tonal balence but will i really notice it?
  4. mike greenslade
    mike greenslade
    Sep 2, 2001
    40
    11
    Neath
    Justin,
    To be happy, go for the matching 'Centre Speaker' with your front Pair. It's been mentioned over and over that the front 3 Speakers are the most important,and its wise to have them all from the same family. I also own the Denon 10SE. What have you set the Speaker Settings at? Fronts (large or Small?)
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    You could of course buy new fronts to match your center ...
  6. Frustin
    Frustin
    i set them all small, all the way round.
  7. mike greenslade
    mike greenslade
    Sep 2, 2001
    40
    11
    Neath
    Yes! So have I.
    I have tried the Front Pair in 'LARGE' and set the LFE to 'BOTH', But I find DVDS are Better when ' SMALL ' is selected all round,and 'SUB' selected.
    I have read recently on Forums and NGs to set the FRONTs to 'LARGE', this is why I was confused and couldn't understand the reason for it.
    '" May The Force Be With You"'
