Speakers for 2nd set up.
Discussion in 'Hi-Fi Stereo Speakers' started by Cut83, Sep 24, 2017.
  1. Cut83
    Cut83
    Sep 12, 2017
    5
    Yorkshire
    Hi I am looking for some budget speakers for a second set up, which will be fed through a Cambridge audio A1 amp.
    So from the following options
    Mordaunt short m10 @ £59
    Tannoy eclipse one @£79
    Or
    Go slightly higher budget and
    Mordaunt short m20 @£99
    All above from richer sounds.
    Or I can still get online the Wharfedale diamonds 9.1 @£99
    I have Heard good things about the wharfedales but as I will be get these off the internet I won't be able to test them in store.
    Any advice would be great thanks you.
  2. Paul7777x
    Paul7777x
    Jul 23, 2016
    3,269
    North east. U.K.
    +1,171
    If you’re after a bit of volume in a larger room then I’d go for the M20s.
    They have a larger cabinet and driver than the rest, so will likely be a slightly easier load for the amp at a given volume.
    Having said that however, Richer Soinds have these on sale ;
    Wharfedale Speakers Per Pair
    An altogether better speaker to the rest from what I can gather.
    They certainly should be at about twice the list price of the others.
    If you can stretch to the extra £20 they’d be a great choice.
  3. Cut83
    Cut83
    Sep 12, 2017
    5
    Yorkshire
    Hi, definitely something to consider at that price.
    Are those models a vast improvement on the 9.1s?
    Volume is not a big issue really I'm just wanting a as decent detailed soundstage as I possible can for sub £100.
    I have the QA 3020s on my main system which I am very happy with so far, I could always go for the 2010s but would like to experience a different speaker if that makes sense.
    Cheers.
  4. Paul7777x
    Paul7777x
    Jul 23, 2016
    3,269
    North east. U.K.
    +1,171
    I’d think they’d be an improvement on the 9.1s.
    Perhaps not jaw dropping, but they are a next step up speaker so I’d expect an appreciable gain in general sound quality; by which I mean the bass will be deeper and should be more fluent, and I’d also expect a bit of an improvement in the midrange as the drivers are a more modern design.
    If you can’t afford the difference though I doubt you’ll be disappointed in with the 9.1s. They are still a well respected bit of inexpensive quality engineering.
