Speakers For £1200
Discussion in 'Home Cinema Speakers' started by Saya2001, Jul 21, 2004.
  1. Saya2001
    Saya2001
    Jul 20, 2004
    90
    HI
    Anyone got any adivce on Speakers for 5.1 System for about £1200.?
  2. Breitling
    Breitling
    Jul 15, 2004
    9
    fronts or surround kit
  3. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    Go to Richer Sounds
    Buy Mordaunt Short THX Select system (£999 bargain!!!! Were £1600)
    Come home
    Connect up
    Smile
    Job Done :)
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    I wish I had a grand spare to do that :( I would rip the guys arms of and then worry how I was gonna get it all home and explain why I have got new speakers to Miss.Dfour :D:devil:
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    As Kazman said, but add a BK Elec XLS200 for £280 as well. Slightly over your budget but should make an awesome sound :)
  6. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Dont forget the THX kit has subs built into the front floorstanders :lesson:
  7. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    The Castle Compact setup should be on your short list. Details here
  8. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    The Castles do have a good rep, I haven't heard them yet though, if space is an issue, they would also be a good buy.
  9. Saya2001
    Saya2001
    Jul 20, 2004
    90
    DONT FORGET A decent SUB would be required for aTHX experince. ANY recommendations????
  10. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    The Mordaunt Short's have a Sub built into both floor standers :)
    If you need more Bass, it may be an idea to add the subs mentioned above (The BK and the MS309).
    It would be better to check out the Subs already in the system first as these should meet THX select specification.
  11. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,230
    2
    +3,722
    You'd need a 909 at least to make any worthwhile difference to the bass performance- Ironically the very first two prototype 309's used 502 amps.....
    The subs in the pack are indeed certified although the 502 is certified as a whole as an active floorstander (we think the only one with a THX certificate although I don't know for certain).
  12. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    I was going to mention the MS909, but that was going to take the budget too high.
    I think the Subs that are built into the floorstanders should be enough, as far as I know, extra MS909 subs were used at the Bristol Show only due to the size of the room. The MS909 would be a great addition later on, but for now, I think the THX Select package would be a great buy.
    You need to be quick though, and phone around a few stores to make sure they have them in stock before venturing down.
  13. alfaman
    alfaman
    The castle compacts are 999, I'd spend the extra on upgrading the front pair of compacts to the castle pembrokes which are their small floorstanders. It will give you a better sound system for music.....
    The finish and build is absolutely gorgeous, leaves the KEF's and such far behind...
    Spent an afternoon demoing these and others at the weekend and my bank balance is the lighter for it (stirling fronts, Bastion centres, compact sub/rears). Oh boy does that hit.....
    Simon
