speakers and RGB to Plasma VGA Converter for me pw7 ?
Discussion in 'Plasma TVs Forum' started by Procter, Mar 8, 2005.
  1. Procter
    Procter
    Oct 29, 2004
    32
    im finally biuying my pw7 first thing tomorrow but for now i want to know where to get some cheap speakers
    but if anyone can tell me that name of the german company where you can buy reallly good speakers from for about £150 quid i will get them straight away
    thanks in advance
    Is it really worth buying a RGB to Plasma VGA Converter from the start ?
  2. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    what would you use converter for?....also if you search for canton speakers in speaker forum you should find german company....it's teck something i think
  3. Procter
    Procter
    Oct 29, 2004
    32
    using the converter for ps2 ntl digital and pc ,someone recommended it
  4. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    it is very good, but whether you need it straight away depends on what terminal boards you have coming and what other kit you have, dvdr, amp etc as they all give connection options. The JS will normally offer big improvements but may be best to see if you are happy with what you have first.
  5. Procter
    Procter
    Oct 29, 2004
    32
    thanks for the words MEP i get the panny with jus tthe scart board which for starters i will hook upto a scart selector box until i decide my next move (eg dvd speakers etc..)
    any ideas people prob have a budget of £500
  6. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    you'll find quite a few all in one solutions for around the 500 quid mark, though i prefer seperates myself, but have a look in the all in one forum for some ideas maybe...good luck with it all mate
  7. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    sheesh....wish I'd known about you before I shelled out over £420 for my cd1 a few months back!
  8. a12yon
    a12yon
    Mar 14, 2005
    22
    Falkirk
    After reading about the Canton CD1 I am seriously considering purchasing it, could anyone suggest a suitable amp to power it?? Im looking to spend about £200
  9. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    i have mine running witha yamaha rx-450 which you should be able to pick up for about £200
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Pioneer VCXS402 is a nice match too as is the Pio 714
