Speakers and furniture
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by raven219, Nov 4, 2003.
  1. raven219
    raven219
    Mar 5, 2001
    532
    East Angular (near Tunisia)
    +15
    It has been suggested that this would tidy up up the living room. Just wondering what would happen to the sound if I am forced into this and my Tannoy M2's get placed in the side shelf units.
  2. wookie
    wookie
    Have you a subwoofer?
    If you have, don't fit the glass:D
    Are the M2'S rear ported?
    If so, block them.
    Blutac the speakers down with the baffle (front of box) level or proud of the cabinet to minimise edge diffraction & try to place the tweeters @ ear height.
  3. raven219
    raven219
    Mar 5, 2001
    532
    +15
    Subwoofer + glass = bad !!!
    Wouldn't fit the doors anyway.
    Yes they are rear ported. Can I block them with anything? Paper, foam etc
  4. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,962
    2
    +3,331
    Believe it or not, a balled sock is often very effective.
