Speakers and Amp
Discussion in 'Hi-Fi Stereo Speakers' started by lokotek, Jul 17, 2018.
  1. lokotek
    lokotek
    Jul 17, 2018
    USA
    I have an amplifier Pioneer SA-8800 II
    Specs:
    Continuous power output is 80 watts* per channel, min. at 8 ohms from 10 Hertz to 20,000 Hertz with no more than 0.005% total harmonic distortion, or 80 watts* per channel at 4 ohms from 10 Hertz to 20,000 Hertz with no more than 0.005% total harmonic distortion.
    10Hz to 50,000Hz .... 80W+80W (T.H.D. 0.01%, 8ohms)
    100W+100W (T.H.D. 0.02%, 4ohms)
    and I want to buy the speakers Pioneer CS-959
    Specs:
    Nominal impedance 6.3 ohms
    Maximum music power 120W
    Rated input power 40W
    The speakers will sound good?
    Will the amplifier reheat?
    If the speakers are not suitable for the amplifier that I have, can they be other models of suitable speakers?
    Thank you very much!
  2. dannnielll
    dannnielll
    Sep 16, 2017
    2,215
    113
    ireland
    +931
    Good news the amplifer will drive those speakers to their rated power output without breaking into a sweat and will be so low down their power curve that the distortion will the .005% level.
    Whether it will sound good.. only you can be the judge. , Just don't overdrive the speakers or the coils will burn out. PLay music and if it starts getting harsh, then back off the volume.
  3. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,626
    +4,309
    The Speakers are fine for the Amp. As to whether they sound good, that's up to you to decide, but I see no conflict between the amp you have and the speakers, or any speakers for that matter, though their could be a few rare exceptions.
    In general though, if those are the speakers you want, then fine, no problem.
    Can you tell us the price of the speakers. Perhaps we can suggest better or different speaker for similar money?
    The Pioneer CS-959 looks like a pretty substantial speaker -
    Pioneer CS-959 - Google Search
    Most people mistakenly assume a large speaker needs more power, that's rarely true. Though any speaker probably needs more power, larger speaker are typically more efficient and actually require less power.
    Again, that combination should work fine.
    Steve/bluewizard
