Hello everyone,
I recently bought a Steepletone ST918 record player to play my old lps on. The sound this record player makes with the built in speakers isn't great, but you get what you pay for.
I would like to buy some speakers and a sub woofer (and an amp?) to use with the record player, which will hopefully improve the sound. It has a red and white 'lineout', and a sub woofer 'out'. I have no idea what speaker system would be suitable for this.
I don't have a very big budget. I just want to listen to my old lps with reasonable sound, so if I can get something half decent for under 50 quid, that would be ideal.
If you could let me know what I should be searching for in order to find suitable speakers, or if you can recommend some, that would be great.
Thank you very much for your time.
John
John
