Speakers, amps, 5.1 - clueless newbie questions..
Discussion in 'Hi-Fi Stereo Systems & Separates' started by nekso, Aug 5, 2005.
  1. nekso
    nekso
    Hi everyone,
    I'm trying to build a home cinema system in a room of my new house, however I'm a total newbie soundwise so, I'll really need some help.
    I already have a 32'' LCD from JVC, all the media is coming from my PC apart from a PS2 and soon, satellite signal. Now, I intend to have a Dolby Digital 5.1 system but my biggest problem is with all the connections I'll need.
    I already have the DVD player from my pc and because most home cinema kits come with a separate DVD player I've chosen to get separate modules. Now how do I connect all the speakers? I guess they all connect to one device (the subwoofer?) but what connection do I need to carry all 5 channels? Do I need 5 rca's? I've got a SB Live on my PC so I already have SPDIF and digital out connections... can I use those? should I use those?
    And do I need an amp? whats the advantages of having one? I was avoiding one because the room is small, I shouldn't need much amplification...
    Sorry, lots of questions I know, but I'm pretty clueless here... :( Can someone shed some light over this?
    Thanks for any help!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    you need an AV amplifier to feed passive speakers (sounds like you have come from a PC background) you need to budget £200+ for an AMP and £250+ for speakers you connect the passive speakers to AMP with speaker wire and if you have an Active SUB you use a single line level RCA c onnection for the .1 channel have a search and a read this will help:
    http://www.dolby.com/consumer/home_entertainment/roomlayout.html
