Speakercraft BassX-12 £199.00...good deal?
Discussion in 'Subwoofers' started by Solomon Grundy, Jun 11, 2005.
  1. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    12,917
    oop north.
    +2,472
    Hi all, At the moment I have the Sony DAVS-880 home cinema system but would like more Bass...I figure that I could just do away with the Sony sub and replace it with an active sub and that would do the trick. If this will work, would the Speakercraft BassX-12 which I have seen advertised at £199 be ok?
    Having just got back from getting married there isn't much in the pot but I would like to sort something out this weekend. Ideally I would like the sonic mines in Attack of the Clones to sound as close to how they did in the cinema (my Sony sub makes them sound like a gnat farting, which upsts me a bit). Cheers.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    I don't know much about DAV's but if the current sub is active then you should be able to replace it with a different type as long as it is just a subwoofer and doesn't contain some of the system electroncs like many of the All In Ones do.
    If the sub is interchangeable I wouldn't bother with the Speakercraft BassX even though I have never heard of it as with a maximum budget of £200 I would buy either the Velodyne CHT 8 that AV-Sales have on special offer or else something seocnds hand.
  3. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    12,917
    oop north.
    +2,472
    The Sony sub isn't active. It is just a speaker in an enclosure. I take it that my plan won't work then. Any ideas on how to get better bass without replacing everything?
