speaker wire
Discussion in 'Home Cinema Speakers' started by Sammer, Mar 23, 2006.
  1. Sammer
    Sammer
    Oct 12, 2005
    123
    16
    How many strands???? is the mnimum requirement for good quality speaker wire?
  2. GW43
    GW43
    Feb 27, 2005
    1,661
    63
    Out of my mind on dope and speed
    +168
    From one to many!
    Some people advocate using 2.5mm2 twin and earth mains cable for speakers. I've used it, it works fine, but it's a sod to get it to lay flat! Ususally 2.5mm2 flexible cable wil have around 80 strands.
    Basically it doesn't matter - the electrons won't care either way.
  3. Sammer
    Sammer
    Oct 12, 2005
    123
    16
    so why do people quote it when seeling the speaker wire?
  4. Jammyb
    Jammyb
    Feb 5, 2006
    4,029
    Coventry
    +576
    On flea bay :p
    196 strand! Heavy Gauge! Oxygen Free!!!!
    It's all rubbish :p
    You've no idea what you're buying. If you look on the cable section of this forum, a little way down the page, you'll see guides on how to make you're own high performance cable from dirt cheap CAT5 cabling.
  5. GW43
    GW43
    Feb 27, 2005
    1,661
    63
    +168
    Because speaker cable being speaker cable, there's naff-all else to say about it!
