jshaun1968
- Joined
- May 29, 2013
- Messages
- 37
- Reaction score
- 1
- Points
- 23
- Age
- 55
Can anyone point memail in right direction which is the best speaker wire on the market
No you won't. Speaker wire is just that. A £2 pm will sound the same as a £100 pm. The only difference is quality of construction really. Obviously I'm talking about OFC wire.It depends, what is your budget
Different wires have minimal effect to sound. You can hear difference only then, if your amp and speakers are very high end.
I agree with you. But I still believe, that in very hi end systems difference can be heard. And one must be really bad wire then. Unfortunately I don't have system like this to testNo you won't. Speaker wire is just that. A £2 pm will sound the same as a £100 pm. The only difference is quality of construction really. Obviously I'm talking about OFC wire.
Agreed. But my point still stands.Unless your running very long runs, then you'd need to spend more on thickness.
Dont write off KnuKonceptz Kord Kable. Compared to Van Damme cable, you get more copper thickness for less money per meter. Even less on bigger reels.
If you wanted to stick to 12 gauge (Approx 2.5mm) then you can go for this at £1.33 p/m
KnuKonceptz Kord Kable 12 Gauge Copper Speaker Wire 30M: Amazon.co.uk: Electronics
Or 10 Gauge cable which is what I use at 2.13 p/m if you buy a 30m reel. Depending how much you need.
I have heard of KnuKonceptz before, though not really familiar with them. I'm suspicious because the price seem unnaturally low. It makes me wonder if it is truly copper or if it is copper clad aluminum.
I use van damme blue 2.5mm.
I spent 100ish on cable for a 5k system.
Good sized room!Same cable here, throughout my system. The longest single run is approx 11mtrs to the surrounds.
Good sized room!
Not really. It's more the route the cable had to take.
