Speaker wire stripping
SteveK72
Are some speaker cables out there harder to strip the insulation off then others? The wire I am using is QED Micro for the rears, the insulation seems harder then some of the other cables I have seen in the past.
I have been using manual and the type that clamps down onto the insulation and the cutters are supposed to cut and strip the insulation off but they always seem to cut some of the strands of the wire too. Then I have to cut the cable and attempt to strip the insulation again as I know its not good to lose strands. At this rate I won't have enough. I be better off using scissors.
AV COM
AVForums Sponsor
Yes, the insulation on the QED Micro and Original are quite hard compared to some others. If you have a cable size selection on your stripper I'd try using a larger size, although depending on the tool this may result in not stripping it at all. The best method is often just to run a nice sharp blade around the cable then give it a bit of a wiggle and the insulation should pull off quite freely. Hope this helps.
