Speaker wire recommendations
Discussion in 'Cables & Switches' started by CrispyToast, Dec 30, 2006.
  1. CrispyToast
    CrispyToast
    Jan 21, 2006
    412
    Llantrisant
    +13
    I am running the setup in my signature and I am currently using QED micro cabling to my rear & centre speakers with biwire links at the speakers and QED original biwire mk2 cable to the iQ5's that are biwired at the speaker end (4 connectors) and connected normally at the amp end.
    What do the experts think of this setup and would they recommend different speaker wire or something else to get the best out of my setup.
    P.S. I might well go for a better amp later in the year.
  2. trevor g
    trevor g
    hi there, i have been using qed original in my home cinema setup for the last
    three years. and can find no reason to change as there is nothing wrong with the sound at all . all connections are via 4mm banana plugs but like every
    thing its every man to his own but i find it ok. regards trevor with best wishes
    for the new year.
  3. recruit
    recruit
    Moved to Cables & Interconnects :thumbsup:
