Speaker Wire close to Electrical Wiring
Discussion in 'Home Cinema Speakers' started by Jules12, Dec 3, 2001.
  1. Jules12
    Jules12
    Oct 29, 2001
    271
    Frinton on Sea
    +10
    I think I read somewhere this can cause interference, if I buy a reasonable quality speaker cable would it then be ok.
    Basically I am looking to run soem speaker cable inside some tracking that has a socket cable running in it.
    If this is correct any ideas what sort of cable to buy, on a budget.
  2. uncle eric
    uncle eric
    Jules,
    No matter how well sheilded your electrical or speaker wire is, I woulden't run these together in a parrellel line as you are suggesting.
    Depending on the quality of your cables/wires, there will no doubt be some interference whether its serious or not.
    If electrical wiring must run across speaker wiring it should do so at 90 degrees. This will cause the least amount of problems.
    Eric
  3. nickeng
    nickeng
    Most of the American Hi mags like Home Theater recommend at least 16" between poer and Hifi Cables of any kind..
