Speaker whine
Discussion in 'General TV Discussions Forum' started by tiger3176, Aug 15, 2004.
  1. tiger3176
    tiger3176
    Hi. I've just bought a Panasonic TX 28PM1. The speakers are making a high pitched whine. Is this normal do you know, or should I take it back. I would really appreciate any help. Thank you.
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Tiger3176,
    If the whine is really coming from the speakers then no, it's not normal and you should contact your supplier.
    However, other parts of the TV, such as the line timebase, do emit whistles which some people can hear.
    In that case, unless it's excessive, you may have to put up with it.
    Good luck!
