Speaker Wattage & Receiver Outputs
Discussion in 'Home Cinema Speakers' started by lee31, Feb 24, 2003.
  1. lee31
    lee31
    Hi, this may sound like an amateurs question but :-
    If I have got an A/V Receiver with say 6 x 100 WPC but my surround speakers are only 75 W rated, will I have a problem ?
    Lee
  2. nathan_silly
    nathan_silly
    Nope.
    Except do not increase volume so high that the speaker distorts (pretty obvious anyway!)
  3. WhyAyeMan
    WhyAyeMan
    Jul 4, 2002
    3,054
    Newcastle
    +287
    Also, depending on the receiver you have, it may not actually be as powerful as claimed...
  4. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    :lesson:
    On the other hand an amplifier rated lower than the speakers can be easily (accidently) driven into distortion and cause clipping - which in return may damage the speakers permanently.
    That said there should be no problem but if you notice any distortion lower the volume immediately.
    Lesson over. ;)
