RFdrummer
Hi guys/gals. Bought a set of Kef eggs ( khs 2005 4x satelites 1x centre and the Kube sub etc gloss black) however this was 10 years ago. Nothing at all wrong with the system as good today as it was when new..except the wall brackets for the 4 satelites, they're all broken. The bracket is a poor design tbh..a tapered arm at a right angle to the part you fix to the wall. The speaker weighing about 5kg sits fixes to the end of the arm where it tapers to a width of 5mm(!!) An allen key bolt then fixes to two together from underneith. So..Q: any idea where i can get replacements or, do the later brackets where the speaker 'hooks on' fit mine? (I cant see how they would.) TIA RFD.
