speaker volume
Discussion in 'Home Cinema Speakers' started by krusty, Aug 21, 2004.
  1. krusty
    krusty
    im using a yamaha a2 with mission speakers and noticed the speaker volume setting in the set up options. are the benefits of speaker volume more to do with room size. the default setting on all the channels is 0...do i leave it at that or [ because my front room is huge] crank them up to +10?
