Speaker V Amp power rating
Discussion in 'Home Cinema Speakers' started by KAZER, Aug 28, 2005.
  1. KAZER
    KAZER
    Feb 4, 2005
    686
    28
    Essex
    +27
    Just a quick question I hopw u lot can help me out with.
    Would I blow a pair of 75w speakers if I connect them to a 100w amp?? :eek:
    KAZER
  2. spiver
    spiver
    Dec 26, 2004
    1,132
    48
    +33
    Possibly. It depends if you run the amp at high volumes. If you do then you stand a good chance of not only damaging the speakers but could damage your amp in the process.
    Make sure that the ohmage of the speaker matches that recommended for the amp. You may have a switch on the back for 4 ohm / 8 ohm.
  3. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    You're far more likely to ruin your speakers by using an underpowered amp at high levels,and running the amp into clipping....this results in large amounts of high frequencies being put through the tweeters,with consequent damage.
    A high powered amp,used sensibly,should cause little trouble,although as spiver has said,if you run it at very high volumes,you could damage the speakers.
    FWIW,my own system uses a set of power amps capable of delivering 200W into the speakers continuously,and up to 800W for short periods...the speakers are arted at up to 150W.....used sensibly,no problems at all,and no dnager of the amps clipping.
  4. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    You would hear severe distortion before the speakers were permanently damaged
