Speaker Upgrade
Discussion in 'Home Cinema Speakers' started by phattanglo, Jan 7, 2005.
  1. phattanglo
    phattanglo
    Nov 6, 2004
    105
    16
    I have posted a few threads regarding speakers as I'm in a quandary to say the least.
    I have a Pioneer VSXC-301 with a Pioneer DV464 dvd player.
    I'm currently using the speakers from the Bush Pro 300 package I started with and naturally I'm looking to upgrade the speakers.
    I have considered a number of packages and am no nearer making a decision.
    I honestly think I would be better off just waiting until I can afford to pay more as I'm sure packages such as MS Genie will reduce over the next 12/18 months.
    I'm more than happy with my Pioneer stuff, can anyone suggest some sub/sat outfits I should consider that will match the receiver and dvd player.
    Given what Tons of fun said about the lower efficiency of the Genie system compared to other systems I suspect I should set my sights lower.
    It would be good if it can handle music occasionally but will primarily be for movies and general tv work.
    It will be in a room 17ft by 12ft, oh and it has to be silver, She says! :thumbsup:
