Speaker upgrade from KEF 1001.2, reccomendations?
Discussion in 'Home Cinema Speakers' started by DocktorJ, Feb 1, 2009.
  1. DocktorJ
    DocktorJ
    Jan 26, 2007
    78
    Manchester
    +12
    Well, the upgrade bug has bit me again... I'm planning on upgrading the front and centre speakers on my home cinema, currently a KEF 1001.2 system. I'm swapping the front speakers for Wharfedale Diamond 9.1's, and I had my heart set on the Wharfedale Diamond 9.CS centre speaker but it's too tall and will obscure my screen! So I'm forced to downgrade to the 9.CC centre speaker.
    Are there any other centre speakers you'd recommend apart from the 9.CC? I want to get a noticeable improvement over my existing KEF centre, which I don't really rate at all, I want to be sure the 9.CC can deliver on that before I buy it! I can spend around £120, it must be less than 160mm high and preferably available in black. Or should I go ahead and stick with the 9.CC centre? Any advice would be much appreciated!
    Thanks,
    Simon
  2. DocktorJ
    DocktorJ
    Jan 26, 2007
    78
    Manchester
    +12
    Anyone?! Going to commit to a purchase tomorrow so any feedback tonight would be really helpful. Do any owners of the Wharfedale Diamond 9.cc have any comments?
    Ta!
