Speaker upgrade. –> elegante E80 system
Discussion in 'Home Cinema Speakers' started by Mouth on Legs, Mar 31, 2005.
  1. Mouth on Legs
    Mouth on Legs
    Jan 10, 2003
    77
    Currently have Denon DVD 3910 into a Denon 3805 and some small embarrassing speakers which don’t do it for me anymore.
    Had a listen to some mission elegante e80 system at local hihf but this was on a top end Yamaha amp Did sound rather good. Going back to listen on a Denon 3805 when they get new stock. Dealer reckoned it is up to the job, and possibly better (sales pitch)
    I do have a wife induced size limit (you know the story) hence the acoustimas system, but following advanced negotiations can go up a bit. The elegantes would be the limit. Already cost me a new sofa cant afford to loose the nuts as well…….
    Can anybody recommend similar speakers to compare them to (size does count)
    Anybody run the elegantes off a 3805, I am worried it is not up to the job
    Any comments about the Elegantes, seem to be generally well received.
  2. avlava
    avlava
    Apr 10, 2006
    334
    +3
    I just bought some of these yesterday. Unfortunately i didnt read up on them before hand as i went in with the intention of buying kef 3005. Anyway with a denon 2807 the kef were ok but not super. Then i put the kefs on an arcam 350 and they sounded brilliant. So i then put the mission e80's back on the 2807 and they sounded fantastic. I couldnt believe it was the same amp.
    Anyway the guy said dont try them on the arcam becuase you wont go back.....so what did i go and request? Yep. Stupid me.
    Anyway although i havent compared much the missions sounded very good to me and the bass was great. Considering i got them for £1449 ( plus some discount becuase i bought other stuff ) i must say i think its a good price.
    Hope others agree...
  3. Booger
    Booger
    Mar 24, 2006
    77
    Whatever you do, don't ever listen to a pair of mission E83's on an Arcam AVR 350 ! :D
  4. Mouth on Legs
    Mouth on Legs
    Jan 10, 2003
    77
    Bought the E80 system, liked them so muc made the mistake of upgrading to E82's front. now I want a bigger amp, considering an FMJ AV9 + P7 umph need to talk to my accountant
  5. Booger
    Booger
    Mar 24, 2006
    77
    If your account says yes, then yes the FMJ is very nice. :)
    Otherwise the Arcam AVR 350 is less money, but very nicely matched to those speakers. If fact mission demo'd those speakers with Arcam AVR Amps I believe !
