Speaker Terminals
Discussion in 'Home Cinema Speakers' started by rgadingan, Jan 17, 2005.
  1. rgadingan
    rgadingan
    Is there a sound difference between Spring clip speaker terminals and binding post speaker terminals? I would appreciate your comments.
  2. Mason @ B&M
    Mason @ B&M
    You want to get a secure contact with a decent sized cable.
    How you do it isn't that important and the connection type won't affect the sound.
    A binding post is likely to make a better connection though.
  3. Beobloke
    Beobloke
    Aug 10, 2004
    1,314
    Out in the Sticks!
    +66
    With all the spring terminals i've encounterd, the words "secure connection" most definitely cannot be applied!!
    Adam.
  4. nsherin
    nsherin
    May 14, 2003
    620
    Portsmouth, UK
    +23
    Don't know about sound difference, but ease of connection with binding posts, as well as the security is a damn sight easier. Trying to use any decent speaker cable with spring-clips is a pain - in terms of time, difficulty and physically! With binding posts, I also use banana plugs, as it makes connection easier and more secure, as well as looking tidier.
