Speaker terminals of Marantz
Discussion in 'Home Cinema Speakers' started by Nik1967, Nov 2, 2004.
  1. Nik1967
    Nik1967
    Jun 22, 2004
    52
    Hi all,
    I am trying to figure out how to connect my banana plug terminated speaker cables to the connectors in the MarantzSR5400. Are the connectors in the receiver only meant for bare wires? How does the banana plug fit in?
    please help!!
    nik
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Hi Nik :) , you need to get a safety pin or small jewellers screwdriver or something similar and prise out the little plastic caps from the centre of each screw down terminal to reveal the 4mm sockets, they are covered up as a safety measure.
    Regards, Mylo :)
  3. Nik1967
    Nik1967
    Jun 22, 2004
    52
    Mylo,
    Do yu mean the small black circular caps in the center of the screw? I hope I don't damage the terminals!! Can those be put back again in case things don't work out? Have you done this on your system?
    thanks and cheers
    Nik
  4. ahin4114
    ahin4114
    Nov 1, 2004
    1,066
    Reading
    +48
    These caps are meant to be removed, they're just small plastic bungs, probably to stop the terminals getting damaged in the first place. They come out quite easily, and yes, they can be put back in afterwards if you need to.
    Tony
  5. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    yes :thumbsup:
  6. Nik1967
    Nik1967
    Jun 22, 2004
    52
    :clap: Cheers. I have got that fixed and plugs connected. Another dumb question....on the speaker side, I guess i have to simply pass the plugs thru the holes and tighten the screw??!!! :blush:
