speaker system
Discussion in 'Home Cinema Building DIY' started by sboy66, Nov 5, 2004.
  1. sboy66
    sboy66
    Hi to all,
    have just bought Panasonic28pm1, Panasonic 27ebs dvd player and wouldlike to buy reasonable priced speaker system. Any thoughts on yamaha nsp100
  2. hatcher
    hatcher
    Can't comment on the Yamaha nsp100 set up.
    Mission do a well regarded setup (5 speakers + active sub) for around £250. If you got a bit more, say £500, Mordant Short have an award winning satellite package based around the excellent MS309 Sub.
    Hatcher.
  3. sboy66
    sboy66
    Thanks, however I am a newbie to the site and after looking around have recognised that i also neded to buy and amp. Have 300 hundred quid to buy both, any views appreciated
  4. bobbypunk
    bobbypunk
    Panasonic make a reasonable amp/speaker pack for £300 called the scht05
    but for £300 you should be able to pick up an Yamaha RXV350 and NSP100, this would be better sound and would get even better if you upgrade the speakers later, but won't look as pretty as the panasonic!
  5. sboy66
    sboy66
    Thanks bobby punk will look on net re best prices
