Speaker System Recommendation for Home Cineama
Discussion in 'Home Cinema Speakers' started by aqureshi, Aug 30, 2001.
  1. aqureshi
    aqureshi
    Can some body recommend good set of Speaker System to be used with Tos DVD 210E, Sont STRDB 940 AV Receiver. My budget is about 300 pounds. What are Mission Cineama 6 speakers like. Also what about Eltax?
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Considered Tannoy Mx series?
  3. aqureshi
    aqureshi
    Thanks Reiner. <br />Which one in particular.<br />What about Mission Cinema 70 or Misson Cinema 6.
    <br />Cheers
    asad
  4. ZZR
    ZZR
    Mission FS2-AV<br />ARC Acoustics Sonare 5.1
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Mx3 + Mx1 + MxC should do the trick. If you find the Mx3 too big/expensive (they are floorstanders) consider Mx2 as alternative for the fronts.
    Add a subwoofer later when funds allow and be amazed!
  6. dAvE6
    dAvE6
  7. hobbes
    hobbes
    Have you seen the new Diamond 8 series from Wharfedale, not too expensive and they are pretty fine speakers.
    On the subject, i to am getting this player but a different amp. I am considering the Wharfedales and Mission M7 series.
