Hi everyone, I'm comtemplating buying speakers to pair up with the Denon 4310.
I'm afraid I'm not too knowledgeable about speakers, so anyone with know how on this receiver please provide your input?
Budget wise, I'm looking at mid- to upper-mide range.
Thanks in advance!![]()
"Mid to upper range" is open to very wide interpretation! Any more info here?Budget wise, I'm looking at mid- to upper-mide range.
Are these speakers for movies, music or both? Any restrictions on size? What is your room size?
What's your budget?
Looking at the outgoing Silver series may let you stick to the 4310, otherwise I think you may have to drop down to the 3310. Unless you're open to the suggestion of building up the speaker package gradually - you could then stick with the 4310 and buy the front LCR speakers for example, and add surrounds and sub later on, giving you a better speaker long term, and the amplifier you originally wanted.
As the Silver series is reduced, it'll allow you to get a full package and still let you get the 4310. Either the RS6's or RS8's with the matching centre, with either the RSFX surrounds or a pair of RS1's as rears, along with their matching sub, the RSW12. This sort of package would normally be around £2,000/2,300, but with them being cleared, the selling price is much nearer the £1,000 mark.
Like I said, the alternative is to look at building up the speaker package gradually, which will allow you to spend say £1,100/1,200 on the front three speakers - any idea which way you'd like to go?
