Speaker stands
Discussion in 'Home Cinema Speakers' started by TEROKNOR, Sep 21, 2007.
  1. TEROKNOR
    TEROKNOR
    Jan 2, 2007
    824
    +12
    Can anyone advise me where I can get a pair of seakers stands for my Hi-Fi speakers.
    There are just a regular pair of speakers that I need to stand on something.
    I have been struggling to find I decent place. They all these new style ones used to Home cinema speakers
    Thanks in advance.
  2. GW43
    GW43
    Feb 27, 2005
    1,661
    63
    Out of my mind on dope and speed
    +168
  3. Dankeech
    Dankeech
    Feb 1, 2005
    3,637
    Stevenage, Herts
    +299
    Hi Tereknor,
    What speakers do you have? It'd be helpful in being able to provide advice. Also, where abouts in the country are you (if in UK) as there may be places near you to have a look at some..
    Dan.
  4. TEROKNOR
    TEROKNOR
    Jan 2, 2007
    824
    +12
    Hey guys,
    I haven't got exact model number here with me but they are JAMO speakes about 12+ years old.
    They are just regular size speakers really. Sorry to be so vague.
  5. TEROKNOR
    TEROKNOR
    Jan 2, 2007
    824
    +12
  6. Dankeech
    Dankeech
    Feb 1, 2005
    3,637
    Stevenage, Herts
    +299
    With regards to height, it's usually best to have the tweeter at around ear-height. I'm guessing you do most of your listening sitting down, so factor your seating position into the equation.
    £50 should get you a decent enough pair of stands
    Dan.
  7. TEROKNOR
    TEROKNOR
    Jan 2, 2007
    824
    +12
    I have taken the width and depth measurments of the speakers and the are about 19cm W by about 20cm D.
    I live down near Gatwick Airport.
  8. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    You will be able to buy stands at any hifi shop including Richer Sounds. They have Gale T50's and Alphason AA3's at the budget end of the scale and do the Soundstyle Z1 which is a real quality stand if you are serious about getting the best from your speakers.
  9. TEROKNOR
    TEROKNOR
    Jan 2, 2007
    824
    +12
    Nice one Cable Monkey. I will check out Richer sounds then.
