Speaker Stands
lunker
Hi All :hiya:
I'm looking for some speaker stands for my Mordaunt Short MS-302's.
I'm using Sony WS-FV11 at the moment and I'm looking for a more attractive stand with more stability.
The Sony stands wobble on my old wooden flooring so I have to wedge paper under one side to keep them up right.
I don't like the hight or the look of the purpose made MS-302 speaker stands.
I would like lower stands at the front and taller stands at the rear am I looking for the impossible?
Ben
GW43
Atacama Nexus - 50, 60 and 70cm high - although check the size of the top-plate - it might be a bit big for your speaker. They would also allow you to use larger speakers later if you wished. About £60/pair
lunker
Thanks GW43 they look cool but as you said the top plate is too large for the MS-302 and I'm not looking to upgrade any time soon.
I've included a quick picture of a stand I've seen in the back of What HiFi but I've since thrown the copy away Doh! (sorry for the crap pic)
Link to picture
Londondecca
If your speakers are not held rigidly, you are detracting from the sound quality, so dont put off buying some stands for to long.
