speaker stands
Discussion in 'Home Cinema Speakers' started by dazed&confused, Apr 29, 2005.
  1. dazed&confused
    dazed&confused
    Mar 12, 2005
    621
    Kettering, Northants
    +42
    I am looking for some stands for my fron Castle Compacts. Width is 14 cm, depth is 15 cm.
    After a search of these forums and the internet I have failed to come up with anything I like that is suitable.
    I would want stands about 70cm tall, 80 cm tall max.
    I do not really like sattellite stands with a narrow single pole. I don't think they are very elegant and they don't look substantial enough.
    The closet thing I have seen is the Atacam Nexus. However, I am really looking for something slightly slimer than this, or at least something with a smaller footplate. Even though I'd like something substantial looking I'd also like them to take up as little room as possible, at least on the floor. I also tend to prefer a single column to the three column Nexus look. The top plate of the Nexus is also slightly to large.
    Any recommendations please?
  2. dazed&confused
    dazed&confused
    Mar 12, 2005
    621
    +42
    So nobody knows of any then?
    I'm now thinking of making my own. Has anyone tried this? Perhaps using tall, narrow blocks of grantite or marble as the base?
  3. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    241
    I am using Partington Ansa 60's under my PMC DB1's. Fit a treat, and could only really be beaten by the dreadnaughts.
    Fish
