Speaker Stands
Discussion in 'Home Cinema Speakers' started by dustjunky, Nov 2, 2003.
  1. dustjunky
    dustjunky
    Oct 8, 2003
    69
    Manchester
    I have just set up my new Aego P5 system in my flat but all my speakers are currently on the floor :(
    Anyone got any good reccomends for stands for such small speakers?
    Also, should my sub stay on the carpet floor or is it better to raise it slightly?
    Ben
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    It's OK on the carpet as long as there are spikes or rubber feet fitted to the sub.
  3. overfloe
    overfloe
    Apr 23, 2003
    230
    16
    Newcastle
    hi dustjunky, just buy any stable stands with the ideal height for your speakers (also your listening position)..
  4. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    I'm very pleased with my new Nexus 6. The base plate is smaller than my Olympus' (which I use for my rear speakers), so they might be worth you checking out.
  5. dustjunky
    dustjunky
    Oct 8, 2003
    69
    Manchester
    Thanks guys - I'll check out those Nexus' :)
