Speaker stands top plate / speaker base ratio
Discussion in 'Home Cinema Speakers' started by tawsi, Nov 1, 2003.
  1. tawsi
    tawsi
    Dec 19, 2002
    102
    Is there some sort of recommended ratio for the top of a speaker stand vs the base of the speaker that is sitting on it?
    I was thinking of getting some Nexus stands and my speakers have a footprint of about 20cm x 30cm and the stands have tops of 14.5cm x 18cm. Is that an acceptable difference between them?
  2. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    I don't believe there's a recommended ratio but obviously the objective is to be as rock solid as possible and it sounds as if the Nexus may be a little small. Ideally the top of the stand and the speaker size should be as near identical as you can get. If you can wiggle the speaker on the stand it's no good. In case you aren't aware, the best connection between the speaker and the stand is Blu-tak - after a while it will virtually fuse them together!
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,565
    Edinburgh
    +1,265
    I would suggest looking at the R series from Atacama which are very stable and suitable for larger speakers.
  4. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Opollo Olympus are sturdy and have a big baseplate which you can attach spikes too. They are on Sale at www.superfi.co.uk if I recall.
  5. tawsi
    tawsi
    Dec 19, 2002
    102
    I think the R series are probably a little out of my price range. Also at 50cm+ the olympus stands seem to be the same size or smaller than the nexus.
    Is the main thing to get the width close to the width of the speaker? I can't seem to find much with a depth close to that of the speaker.
