Speaker stands for kef tdm 23's
Discussion in 'Home Cinema Speakers' started by fatrich, Jul 25, 2001.
  1. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    can any one suggest where to get these stands and how much they roughly cost.Also is there an alternative stand that can be used, at the moment my current speakers are on atacama se24 but i don't know if they will be ideal.
    thanks in anticipation
    richard
  2. Ron Locke
    Ron Locke
    Hi Richard,
    We at KEF produce two versions of the TDM23F stand. You have a choice of wooden or metal construction. The wooden version have the same contour of the cabinet and have a MSRP of £299 per pair, the metal stands have a chamber which allows you fill with lead or sand though are of a conventional speaker stand design, which also retail for the same price.
    You will have to visit an authorised KEF THX dealer to obtain these items. If these are out of your price point then I recommend the Target R4 or just keep the Atacama SE24 which are great stands already (though I would fill them completely with lead or sand (kiln dried)for optimum weight and isolation.
    Best Regards
    Ron
    KEF Audio (UK) Ltd
  3. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    Ron
    thankyou very much for for reply
    richard
