Stretchy
Hi all. Just wondering if anybody had any experience with the Custom Designs RS300 speaker stands, specifically the size of speakers that will comfortably go on, i have Q Acoustics 2010i.
I've just relayed my entire av set up with a new unit and tv, the slight issue is the space left for new speaker stands. The soundstyle z2 fits the speaker well but the base is a bit to wide, the rs300 base is about right but the top plate is larger. The speakers are D: 203 by W:150 and the stands W165 by D180. I appreciate there is not a lot in it but will it make a huge difference? Could always add on some pods to the top plate. Thanks in advance or if anybody knows of a good alternative. Stands will go either side of the unit.
