Quantcast
Speaker Stand Recommendation For B&W 602 S3 Bookshelf Speakers
EViS
Could I have some recommendations for a pair of stylish, but mid-range price speaker stands for a pair of B&W 602 S3's? I've had a pair of Apollo Olympus stands for as long as I can remember and fancy a change :).
EViS
A bump to see whether there are any recommendations, even if it's just for manufacturers to stick with so I can whittle down the vast selection a tad?
Andywilliams
Well being as know ones replied I will tell you the ones I use they are Atacama hms 1.1s you can get a mass weight for the bottom plate for added mass and you can also fill them with atabites or kiln dried sand when filled they weigh an absolute ton. They are expensive but will stand the test of time when you eventually upgrade your speakers. If to expensive have a look on atacamas site plenty of excellent mid priced stands.
Hixs
I use the Nexus range form Atacama.
EViS
Thanks for the replies and recommendation for Atacama, they seem to be stocked all over. Any thing in particular I should look out for in terms of design/features?
Hixs
Cable management is a bonus.
Stands that can be filled even if you don't do it
Make sure speaker/stand fit nicely
Get the correct height
