[email protected]
Can anyone advise on what i should set the speakers to on my Denon 1507 amp. I have the Tannoy FX 5.1 and you can set the satellites to either small/large depending on their frequency response. Frequency response is where i get a little lost and even if i knew what it was i would not know what is low enough to have my speakers set to large.
Also if i purchased the new centre speaker on its own from the EFX5.1 range and use the spare satellite as a centre rear does it make much differance.
Thanks in aticipation of anyones help.
wolfy!!!!
wolfy!!!!
