speaker setup - what speakers ? ?
Discussion in 'Home Cinema Speakers' started by jibber, May 6, 2005.
  1. jibber
    jibber
    right i pose a question here...
    i have a sony home cimema amp and reciever..
    but i do want to get a proper speaker set up for this however....
    i have two young children who would tamper with the floor standing speakers hence i need to get the speakers off the ground and on to wall brackets etc..
    can anyone suggest a nice small compact speaker setup which is not of the price scale of the bose price range (i.e £4k)
    i'm only after a 5.1 setup, so two rears, two fronts and a center front speaker
    look forward to researching into some speaker packages.. :)..
    Jibber.
  2. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    Sounds like you're after a sub-sat package, so you're pretty much spoilt for choice at the moment. Depending on how much you want to spend and your music/cinema usage, you may want to consider packages such as:
    Mordaunt Short Genies,
    Kef 2005.2 (eggs)
    Monitor Audio Radius
    Tannoy FX
    Castle Compacts (?)
    and I'm sure others can add more. Do a search on the forums for each, and you should find a wealth of information, comparisions, preferences, etc.
    If you post your size/ usage/ price considerations, I'm sure you'll get some good recommendations from other forum members.
    My personal preference was for the Kef 2005.2 package (which IMO look the best of the above speakers, even though they've since been beaten into second place performance wise ... others may disagree ...). I've replaced the front three recently with larger speakers, as I moved house and had more space available to me, and must admit that the eggs can't touch the larger floorstanders for sound quality.
    Alternatively, you could got for small bookshelf speakers, and mount those on the wall, but I'm afraid my knowledge of those is limited.
    Just as an observation, my floorstanders aren't particularly interesting to my 3 year old. He had a look when I first installed them, was told not to touch and now doesn't give them a second glance (or touch). Guess I'm just lucky! (or is that just tempting fate?)
    Balders.
  3. PeterKay
    PeterKay
    Why not go and demo:
    Mission M cube
    Or
    Monitor Audio Radius 90 x4, 180, x1 and 360 sub
    Used the Radius for about 6 months will worth the money and very cool
    Hope that helps
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    There is also the canton cd1 on special offer in the power buy section at the moment and if you have more money to spend you should also look/demo some of the M&K series of speaker systems.
    http://www.mksound.com/whatsnew.htm
  5. jibber
    jibber
    thanks chaps..
    i'll get looking into the matter of which speakers to get....
    i have two children one who's 4 and one who's 1, my eldest is fine and does not bother with things but my youngest is just challenging our authority at present..., everything we try and do just does not work.., he clibs like a monkey, moves things around the room all sorts go on, i just can't wait till he's a little older and has things he really likes which we can take away if he's naughty...
    i just want to make the right desiciion as far as speakers go hence why i'm taking my time..
    also for the speakers commmented above what kind of price range are these makes in ?..
    Jibber.
  6. Rawschach
    Rawschach
    Nov 8, 2004
    1,420
    116
    sunny halifax
    +1,047
    my son is two and has just destroyed one of my mission 774 speakers by pushing it over. I think you are making the right choice
