Speaker settings large or small?
Discussion in 'AV Receivers & Amplifiers' started by steve 111, Sep 24, 2004.
  1. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Just bought new speakers (Monitor Audio Bronze B4s with BFX rears). The range of each speaker in the set up is as follows:-
    B4 Fronts 36hz to 22khz
    B4 Centre 60hz to 22khz
    BFX Rears 65hz to 22khz
    Previously I had Kef Eggs and had them all set to small, but as this set up has different ranges how should I set them up?
    Also, what should I set the crossover frequency for my sub too now 40hz, 60hz or 80hz?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,402
    Rainham Essex
    +2,452
    To start with I would recommend setting all speakers to small and crossover to 80hz. This is the THX recommended setup and with my old system (Denon 3802 & B&W DM603 front, 602.5 surrounds, LCR60 centre) worked very well for me.
    If, like most of us on these forums, you want to play around at a later date you can try different settings to see what works best for you, but the above at least gives a starting point to refer back to.
    Mark.
