Question speaker set up (wiring)
Capnbob
just had delivered a pair of Monitor Audio Bronze 2.0 front speakers and centre speaker. The fronts (opened thus far) have HF and LF terminals - im running a simple 7.1 set up with one set of wires -which do I wire to?
TIA
Gasp3621
TIA
Pick freely as long as you keep the metal terminal links in place!
Capnbob
Another question
I got some QED micro speaker cable but it doesn’t differentiate plus or minus - how am I to know what’s going where or doesn’t it matter?
youngarthur
Yes it does matter. One side of the cable might be coloured, or stamped with the make, but there should be marking of some sort. The cable probably has markings on one side. Use that as the plus, to join plus to plus.If still not sure, post a picture of the cable.
Similar threads
LG CX 4K OLED TV Review: The best TV of 2020?
